JJsays77
- Joined
- Sep 21, 2011
- 59
The hole to the left of the vented filler cap or the two nipples on the hose connector on the right?
Does the tank have any manufacturer markings? What is the capacity? Looks like about 6 gallons.
It looks like a semi-permanent tank or a semi-portable tank. It has elements of both. The thing to the rear looks like a sender could mount there and portables don't have sender. The cap is vented and permanents don't have vented caps or caps at all.
Where was the tank mounted? Filling it could be hard to do because tanks like this are usually held in place with straps and not easily slid out or back in when full.
A strange one.
I would get the right size plug for the hole. A plastic plug has no place in a metal gas tank.
After about 10 years of floating in E10 gas, the lacquer on the cork floats dissolve, and they sink. Easy fix. A neoprene carb float from a Mercury outboard works fine.That part is not a sender unit. It's just a mechanical fuel gauge. Which doesn't work by the way because the cork? or wood? Doesn't float anymore. Was hoping you or someone knew what I could use to make it float and work again and not be destroyed in gasoline?
Also, I just bought this boat, and noticed something odd on the fuel connector on the motor (1985 90hp Evinrude)? Maybe this explains the extra tank hole? What is the extra nipple for on the motor?
