What is the green foam in my 1969 45 hp Chrysler lower unit?
Red9654
there is a green foam in the lower unit of my 1969 chrysler outboard. what is it? and in the 3rd pic it is oozing out of a hole in the black part. there is a hole like that behind it with somethin like a screw or somethin it in. should there b something in the hole where the green foam is oozin out?IMAG0350.jpgIMAG0351.jpgIMAG0349.jpg
jerryjerry05
Re: What is the green foam in my 1969 45 hp Chrysler lower unit?
No idea what's oozin.
The hole's a weep point or drain.
Usually it drains unburned gas /oil from the hole.
The screw?? DON"T remove it or you'll be doing a lot more work.
Drain the oil from the bottom screw/plug and see if it has water or oil?
Red9654
Another question, alot of times gas comes outa my carb where the choke flap is. Can i stop that from happenin?
Red9654
And what is the screw under tis drain hole the ooze is comin out of?
wickware
Red, Please do not touch the screw at the very bottom (above the 10 in the date) not ?marked vent or fill?). I would even cover that Monster with silicone to hide it to prevent a Nightmare.
Red9654
i already removed it thinkin it was the screw to put gear oil in. i didnt put anythin in it tho. what is that screw for and could me removing it b a cause of y my motor isnt runnin right now?
wickware
Good Luck!
Red9654
Is it bad that i removed it?
wickware
Maybe not bad, if you got it back in before pulling or pushing the shift rod. Causing the screw’s fork and screw’s alignments to be off (adding more work as Jerry mentioned.
Are you using a Manuel or past experience related to your challenges? If not, Good Luck! I’ll move on but monitor your progress vs sharing my limited info/time.
Red9654
So if i just took the screw out and put it back in within 5 seconds without movin anythin there are no problems then if i can still change into all 3 gears?
tater76
I have seen similar green foam from very little gear oil and a little water being mixed together at high speed (think whipped egg whites). I could be wrong, but like the others said, drop your drain plug to seen the condition of what's inside.
Red9654
I have and there is just oil in there. I will b replacin it soon. And can someone please tell me if it is bad that i removed that long screw mentioned above but quickly put it back in without movin anythin???
eurolarva
If you removed the pivot screw and you put it back without shifting you are probably okay. Have someone slowly move the shifter while you are turning the prop with your finger. When you hit neutral the prop should spin in both directions with no clicking when you go forward or reverse the prop will lock up and not turn. The froth you are seeing is unburned two stroke oil. Make sure the pivot screw is good then fix the green foam later. The foam can normally be fixed by de carbing the engine
jerryjerry05
No the screw is probably ok,if you didn't shift it your ok.
The shift pivots there and if it's taken out and the linkage is move you'll need to take the lower apart and install it right.
But it sounds like your ok.
If you found only oil in there.You should be ok.
Clean it up and see if it happens again?
