- Joined
- Mar 8, 2009
- 43,317
Working on a complete engine rebuild along with a new outdrive, Question is I currently turn a Bravo 3 at 5300 RPM max and the drive is a 2.0 ratio running 24 pitch props. Currently have 3 sets of B3 props and would like to use them to fine tune the WOT. When the engine comes back it will produce more power and therefore I if I producing 100 more HP I should over rev with using my current 24 pitch props. So the question is if I change my current ratio drive from 2.0 to 1.81 I will increase the rpm of the prop above 2500 rpm, is there an issue?
