What is the proper knot to use to tie to a docking circle.
spikeitaudi
Was docking a restuarant this past weekend on my lake and was tying off to the docking circle they have. Starboard side bow and stern. What is the proper knot to use on the docking circle?
JoLin
Re: What is the proper knot to use to tie to a docking circle.
Sorry, I've never heard of a 'docking circle'.
Piling? Cleat? Bollard?
Mike Robinson
Are you talking about a metal ring? If so a "round turn and two half hitches" would work.
http://www.animatedknots.com/roundturn/index.php
You may also be able to thread your mooring line through the ring and bring it back to the cleat on your gunwale. (if you have cleats)
spikeitaudi
Sorry it's a metal ring that is clamped down to the dock.
spikeitaudi
Never thought of bringing it back to the cleat. That is a great idea. Sorry for the newbie question but I had to ask. As I felt kinda dumb sitting there trying to untie this knot I mad. It help good but was hard as heck to untie.
redone4x4
A bowline would also work, and is ALWAYS easy to get loose again. its a great knot for all sorts of stuff, i use it more than any other.
sasto
I prefer Mike's method, especially when I have non-boating guest or single handed. Guess that means all the time. 2 reasons for me, and both are related to the same thing. All are onboard when casting off. Nobody touches a cleat till I say so. How many times have we seen beginners straddled with one foot on the dock and one on the boat. The drink wins almost everytime.
spikeitaudi
Thanks guys. That is a huge help.
spikeitaudi
Yea that was what I was thinking also.
rbh
Try a clove hitch, then a half hitch to lock, for most tie offs.
clove hitches are adjustible.
JoLin
Yup- if there's one knot you should learn to tie, it's a bowline. Doesn't slip, doesn't jam. Definitely the most versatile of all.
Even if you use it in an application for which it wasn't strictly intended, nobody'll give you grief, 'cause, well, you know how to tie a bowline :)
Ayuh,... I use it all the time when I need a Loop in the end of a line,...
When faced with a Ring, instead of a Cleat,...
I use what I was told is an Electrician's Loop,...A loop in a loop...
Push through the ring a loop, then another loop through the loop you just made, then another loop through the loop you just made, etc, for as Long as you'd like...
For total security, put the tag end through your last loop,... It'll never give up...
Or, I leave the tag end laying, so that when time to fly, you just Pull the tag end,+ the loops all disappear,+ your Untied....
sasto
For total security, put the tag end through your last loop,... It'll never give up.....
Clever......
Home Cookin'
while we're on the subject--all seaman's knots are designed to release no matter how tight they've been pulled. A bad knot won't. Compare a granny with a square; an overhand with a figure eight.
They are also designed to lock onto themselves: as they are pulled from the working end, they tighten back against the loose end. For that reason, you seldom need extra wraps. Drives me crazy when someone wraps 10' of line around and around a cleat; the top two passes is all you ever need.
Most knots are one of two varieties: the square (including the sheet bend, reef knot and bowline) and clove hitch (cleat, two half hitches). Even the wierd ones, like a sheepshank, is a clove hitch.
