Re: what is the purpose of a converter?
That depends on what type of "converter" you have so a Manufacturer and Model number would help. When connected to shore power, the converter directs 115 volts AC (house power) to the AC outlets in the boat. The converter also converts 115 volts AC to 12 volts DC to power the 12 volt accessories. You said the charger is not working but how do you know that? The converter also provides a battery charging capability as that's how the 12 volt accessories get their power. If the charging portion of the system is not working you need to check the panel for tripped breakers, transfer switch setting, battery connections, battery switch settings, etc. I have no idea if your boat has any or all of these features but if it does, they are all sources of failure.
