what is this??? #1 cylinder
76delro
so finally got all the parts that i need for gasket repair. so today got enough courage to tackle the job. first compression check... results 1@30#, 2@120#,3@120#, 4@120#. second the bolts... finaly got the cover off and did not expect what i saw check out pics...
so what is next for me
R.Johnson
Re: what is this??? #1 cylinder
Looks like detonation, Probably from carb leaning out. What plugs are you using?
76delro
using champion ql82c thanks....
is it costly to repair. soory what do youmean by carb leaning out..
F_R
Yep, detonation/preignition, whatever you want to call it. In older cars you could hear it "ping". The fuel was exploding in there instead of burning normally. You can see the piston top is actually burned away from the intense combustion temperatures. It is caused by several things, most likely running too lean on that cylinder. Carburetor jet partially plugged up is suspect. There is a separate jet for each cylinder in case you wonder why the rest weren't affected.
EDIT: Expensive repair? You bet. The powerhead has to come completely apart and piston replaced. Possibly re-bore, depending on what it did to the cylinder. Probably a couple $thousand or more, depending on local rates and other possible damage.
Dennisanoka
A couple of $thousand if you pay to have it done or a whole lot less if you do it yourself and do a thorough rebuild.
