86IROC
- Joined
- Apr 5, 2010
- 89
I was in the process of winterizing my boat and following the service manual. It said to raise the outdrive and remove the drain plug on the port side. I removed the one in the center of the outdrive as it has lots of wear on it like it's been removed a lot.
Well..whatever it was screwed into isn't there anymore. :facepalm:
The manual also said to remove the upper and lower drain plugs from the starboard side. I only see one in the area that the arrow points too and there is no screw there. The hole was full of silicone.
I have a second parts outdrive and there is no screw in that one either or threads in the case. What is suppose to be there?
