What is this code and how do I fix it
Steveallen007
I have a 2001 Evinrude 40 hp 4 stroke that came with the lake property we took over from my in-laws. Last time we went out it shut down to an idle. I changed the old fuel lines, primer pump and conections. I also changed the large fuel filter. The connector on the tank didn't fit correctly so I sucked all the fuel out of the bulb and lines while trying to start it. Now I'm getting a check engine code.
1 flash short pause 2 flashes long pause, 4 flashes short pause 2 flashes long pause, 4 flashes short pause 2 flashes long pause, 4 flashes short pause 2 flashes.
dingbat
Here are the flash codes
