Getting ready to make a wiring schematic for my boat
I think you are about to answer your own question! Finish your wiring schematic, and THEN try to figure out what it is. I'm guessing the answer is going to be alot more clear once you know what it is connected to.
If I were a betting man though, I'd say livewell timer. Clean off the top of the IC and post the numbers. Again, if I bet, I'd say there is probably a '556' somewhere on the top of that chip. It looks A LOT like a LM556 timer circuit with a relay to turn on/off a pump.
(the square box is a relay, the little guy to the right is a transistor to drive the relay, a couple resistors, a couple capacitors, and what looks like a standard lm566. yep, timer)
