what is this tube for?
carey965
looks to me like a vent tube of some sort, maybe a crankcase type breather not sure
i was looking at my lower unit lube hose to make sure it wasnt leaking and i saw this hanging off, it looks like it goes on the nipple on the lower unit
just wondering if i should replace it or make sure it doesnt come off the nipple or what
sorry for the blurryness i took it with my phone
also here is the serial number if that helps
its a 98 alpha 1 gen 2 4.3
carey965
Re: what is this tube for?
so thats why it doesnt work, does it work on pressure?
GA_Boater
Yes. On the lower unit leading edge is a hole that supplies the pressure to the hose and to the speedo. Just plug it back on the nipple. It may fall off again.
carey965
i was thinking about using a zip tie to hold it on
dubs283
there is a coupler assy that holds the tube to the connection on the shift shaft seal housing - they break fairly easily
the new style is a quick connect and much better, just get a new style shift shaft seal housing and you get a new connector with it
