ddavis90325is
- Joined
- Sep 16, 2005
- 62
My 1984 35hp Evinrude is running on one cylinder. I have 130lb of compression in each cylinder, and i have spark on both cylinders. I re-built the carb and fuel pump and it's still running on one cylinder. One thing that i think may be causing the problem is this so called "electric primer" which would be the electric choke.
It effects how the engine runs when i turn the red switch on the top of the unit. What exactly is this, and could this be what is causing my engine to run on only one cylinder? Thanks!
