Re: what iws this
Re: what iws this
LOOKS LIKE THE IMPELLER IS "TOAST" , good idea to replace, alos looks as if some of the impellar blades are missing, could cause blockage further up stream from the water pump to the tell tale "pee hole" with LU off back blow thru tell tale with compressed air to make sure all is clear and free of bits and pieces,
sorry mis read on h20 pump change, :facepalm: ?? works off key ;on start up if needed i still need to time it . if refering to h20 pump should be peein at start up at least within a few seconds , unless your motor has a thermostat then it will take a bit longer until it opens up,
