I flush mine a lot if you have a Mercruiser and your going to keep it. Buy a fluid evacuator.get one that holds 6 quarts if possible. You will find you change your fluids in everything you own more often. Brake fluid power steering fluid. But especially your trim and engine oil oil in your boat. Harbor freight sells a 6 gallon one for $149 may be an overkill for one guy at his house but the 6 gallon one is nice for larger things. Suck the fluid out of your trim pump a couple times a year. Im sure your seals are taking in some water havent seen many that dont. You can use 10/30 if you want but its pretty cheap to buy actual mercruiser trim fluid or Sierra packages it as well. Ive worked in shops without them and when the techs see them in action soon the shops buying enough of them that no ones waiting for one. So they really are handy.
