Re: what do ineed to do to make 250hp
It can be done with your block but the 93 and newer blocks are better as they are fingerported. My Junkrude started as a 1999 200/225 engine block. I had all sleeves removed and I die grinded out the casting and flashing in the intake transfer ports and smoothed the transitions as the castings suck at lining up to sleeves. Had new sleeves installed and exhaust ports raised to 225 HO spec's, water mod's done to block, no exhaust relief holes, running a set of trued 1987 2.7 heads
with water passages modified for 3.0, 1989 300hp carb bodys and throttle plates, 1990 200hp throttle plates to make it idle, 30 idle jet ,22 midrange,drilled out and tapped vent bowl to 1/4 -20 and installed jet drilled to 104 size to richen midrange cruise and 81D high speed jets, CDI all digital ignition system,20ft Javlin DC, lighting gearcase,14 inch set back jack plate,Dyson 28pitch prop, 5800 rpm GPS @73.8mph full load, best run empty 81.3mph GPS. Thinking about going to Brucattos fuel injection for the loopers as gas is killing me(89 octane). You will spend around $ 2800-3500 to have done right,but if you got a "pig" hull you are just throwning money away.
To go fast you need (1)$$$$(2) Performance hull (3) HP (4) Setup and tuning of engine to hull
