What is VST on F115 ?
loyoki
Hi, pardon but I am french and I do not understand all your english abreviations.
I have also idle trouble shooting on my 2002 Yamaha F115 and the problem seems to be the same I saw on few threads, I have to clean VST filter, but what is VST ?
Many thanks
Lo?c
France
loyoki
Re: What is VST on F115 ?
Ok many thanks, your link is fantastic.
I will clean this part #8.
I think I have to remove Intake to acces the VST ?
King regards
Lo?c
sdsaw
Yes, you will have to remove the intake to access the VST.
If you have a digital camera, I highly recommend that you take pictures of the way the wires and hoses are routed so will be able to reassemble it correctly. I'm very glad that I took some pictures of the way that the hoses were routed.
I had mine out recently and this is a back view of the intake.
Is your running issue only happening at idle?
Describe the best you can, your symptoms. Maybe somebody here can steer you in the right direction.
Scott
loyoki
ok many thanks, I will post a new thread for idle problems.
