What Keeps the Thermostat in?
Hvymtl
1999 305 - GL50PEFS - what holds the thermostat up in the housing and keeps it from falling down into the manifold - just the rubber grommet??? Just doesn't seem right
fixnfly
Re: What Keeps the Thermostat in?
Thermostat housing keeps it in place. Rubber o-ring keeps a seal, from water bypassing the thermostat.
500dollar744ti
Maybe you have the wrong thermostat if it's small enough to fall into the manifold.
Jarrod B
That is what holds it. Just use a screwdriver to get it seated good.
dypcdiver
Make sre you clean any rust out of the "O" ring groove before fitting it, works just fine.
jerryjerry05
What are you doing?
Replacing or reinstalling?
Is it the right one?
A bit more info and pics always help.
