Re: What kind of BATTERY
If you read in your manual, I'll bet it will say that you need a minimum of 350 cca (cold cranking amps) for your starting battery. <br /><br />Personally, I have a 850 cca compromise battery on my 86' merc 175.... Compromise means that the battery has both the capacity for starting and trolling purposes...I'm not saying that's what you need, but Wally world has them for around $69... It's yellow in color.. <br /><br />Anyway a 450-550 cca battery will be plenty to start your motor... Just make sure it is a marine battery like DasBood said. If you run a lot of gadgets while the motor is off, you may want to look at something like I have.. Good luck...
