what kind of bilge paint and topcoat paint to use on top of epoxy
tpenfield
Re: what kind of bilge paint and topcoat paint to use on top of epoxy
Last year I bought the bilgeKote paint at west marine . . . Only to find out that it is basically the same as the floor and porch Enamel that is sold at ace hardware at 1/3 the price.
So, I needed to do some more bilge painting and went to ace hdwre
panamacitymustang
Really its the same thing that's Awsome
Woodonglass
Well not exactly the Porch paint has no UV protection as well as some other components. Need to do some research on the specific chemical make up specs for both.
panamacitymustang
that's what i was worried about the uv protection. what else is there to use that has the uv protection. i tried to search what was out there but not really having any luck.
tpenfield
Pretty much . . . looks the same, smells the same, tastes the same, most all the same chemicals listed on each can . . . could not see paying the difference in price for something that close for bilge paint.
Woodonglass
Rustoleum Professional oil based paint with acrylic enamel hardener. $50 bucks for paint and hardener.
panamacitymustang
I was doing some reading about that some people said it wasn't gas resistant. Is this true
Woodonglass
It's in my boat and working just fine. I've had some gas and oil on it, not much but some. Always cleaned up quickly
panamacitymustang
Ok cool i wasn't sure if you could use that on epoxy
panamacitymustang
Thanks for the help woodonglass and tpenfield
I have used sherwin williams industrial floor epoxy in a bilge once. It works on the floor and walls of my friends towing/garage business, it worked in the bilge. a bit more expensive than rustoleum though
panamacitymustang
I was looking into the sherwin williams floor paint I'm not sure if it has the uv protection yet
panamacitymustang
hi woodonglass ok so i'm going the rustoleum route can you tell me the correct way to do this with a roller. what is the mixing ratio. do i need to thin the paint it out.
Woodonglass
Check the link in my signature
