ezmobee
- Joined
- Mar 26, 2007
- 23,767
I'm getting ready to do a cooling system flush and fill on my 2005 Jeep Grand Cherokee. I bought two gallons of non-diluted Wal-Mart SuperTech long life antifreeze which I assume is the green stuff. Went to do the job last night and it looks like it's got the red stuff in it now. Can I replace the red with the green? Should I be using something else altogether?
The WKJeeps site said this which I didn't really understand.
I think the SuperTech is ethylene-glycol but says nothing about having HOAT in it.
Mopar Antifreeze/Coolant 5-year/100,000 mile formula
p/n 68048953AB (formerly 5066386AA)
MSRP $21.95/gallon.
The recommended mixture is 50/50 ethylene-glycol and water. Never use pure antifreeze.
The use of aluminum cylinder blocks, cylinder heads, and water pumps requires special corrosion protection. Mopar? Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769), or the equivalent ethylene-glycol base coolant with organic corrosion inhibitors (called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant offers the best engine cooling without corrosion when mixed with 50% ethylene-glycol and 50% distilled water to obtain a freeze point of -37?C (-35?F). If it loses color (red/orange) or becomes contaminated, drain, flush, and replace with fresh properly mixed coolant solution.
Notes:
Antifreeze mixture must always be at least 44%, all climates year round. Maximum protection (-90d) is provided with a 68% mixture protection.
Do not change the thermostat for summer or winter operation. If replacement is ever necessary, install ONLY the correct type thermostat. Other designs may result in unsatisfactory cooling performance, poor gas mileage, and increased emissions.
CAUTION: Use of Propylene-Glycol based coolants is not recommended, as they provide less freeze protection and less corrosion protection.
CAUTION: Mopar? Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Mixing of coolants other than specified (non-HOAT or other HOAT), may result in engine damage that may not be covered under the new vehicle warranty, and decreased corrosion protection.
CAUTION: Do not use coolant additives that are claimed to improve engine cooling.
Avoid non-HOAT mixtures, such as Prestone 50/50, that claim they can be used in vehicles of "all makes, all models".
