Re: What leaf spring capacity do I need?
Here is how this works:
What is the capacity of the axle. For an axle to carry its rated weight, it needs hubs, wheels, springs and tires each of which is capable of carrying "at least" 1/2 the axles rated capacity. There are two of these so each side carries 1/2 the total capacity. So if the axle is rated at 1500# then each side of the trailer needs a 750# hub, an appropriate wheel (8, 10, 12, 13, or larger) and appropriate tire capacity. It also requires 750# springs. However, if the total GVW (gross vehicle weight) which is the boat, the trailer, and everything in or on the boat (gas, engine, supplies, and gear) is only 750 pounds then everything can be derated. But if you do that you then need to change things again if buy a newer and heavier boat. So start with the axle and work up to its carrying capacity. Iit is very common for "estimates" of boat weight to be very wrong -- and very wrong on the light side. Most folks forget about the engine and everything that goes into or on it. The reason I mention this is suppose the axle is rated for 1000# and you put appropriate springs, hubs, tires, etc., on it. Then it turns out your boat and all the gear actually weighs more than that. You now have an overloaded trailer. Putting larger tires on does not solve the issue because you still have overloaded springs and axle. So the entire system needs to be rated to carry the total weight (GVW) "minimum"
