Boat: 2007 Sea Ray 185 Sport
Engine: 2007 4.3L I/O 190 hp carb
Alpha 1, Gen 2
Hrs: 180
Bought the boat in Feb 2013. It had 140 hrs on it when I bought it, no problems whatsoever. Put about 40 hrs on it until the last time I took it out (October 2013). A couple weeks ago I pulled it out of storage and ran it on the hose for about 30 minutes. Started just fine, idled fine, got up to temp just fine, etc...etc. No problems. Added some Stabil to the full tank of gas, hooked the charger up and topped the batteries off (they were still fully charged, both are interstate, new in 2013), washed the boat, and put it away.
As it starts to warm back up now, I'm thinking I'd like to do any maintenance items now so that it's ready to go for the 2014 season.
What are the items I should do based on hrs/age (lets assume nothing has every been done before)?
What are the things i should "check" while in there and have it apart?
Here's what I can think of off the top of my head:
impeller
water pump (should i need to do this yet?)
new belt (it looks fine, would you do it anyway?)
new gear oil
new engine oil
spark plugs (should I need to do this yet?)
check bellows
check gimbal bearing?
change oil filter
change fuel filter/water separator
Anything else?
Alpha 1, Gen 2
Hrs: 180
impeller
new gear oil
new engine oil
check bellows
change oil filter
Anything else?
