Re: What makes a marine engine a MARINE engine
I was thinkin 5.7 with vortec heads. Shouldn't that make a pretty substantial difference? Wont that be a good 50 hp increase. Mine's a 228 hp.
You can use lookup truck hp numbers to get an idea of what you might expect.
a pre-vortec 305 makes about 200 HP in a truck.
Because of better exhaust and intake, boats always make about 15% more HP, given identical components (heads, cams, intake, carbs)
so 200HP +15% is 230, which is bang on with what you have.
a vortec 5.7L makes 255 HP in a truck. adding 15% works out to 293 HP.
So if you took a 255HP 5.7L vortec out of a truck and simply dropped it into you're boat, it would make 293 HP roughly.
