What material to use for bundeling wire harness and cables?
beagleboy
Can anyone suggest what to use, to bundle electrical harness, cables etc between the motor and transum?
ONERCBOATER
Re: What material to use for bundeling wire harness and cables?
the black (or other color) wire loom stuff and black tape.
Personally i prefer thick heatshrink.
both are good.
Sean
saltydog45
I would go with what wilde1j has recomended. It is an easy install, it has a clean and professional appearance to it and the tube is large enough for everything.
ONERCBOATER
yep their answer is better. :)
RRitt
check grainger for wire loom, split loom, etc. they will have wide variety of colors and sizes. a small zip tie makes a good way to secure a wire loom to the hull. For tape, use self-fusing silicon. It won't melt open like electrical tape. For wire splices nothing beats a good barrel crimp & solder with a bit of heat shrink tubing. If in a wet location you can get tubing that has an thin inner coating of hot-melt glue.
