What model Honda
Dirt Crawler
I have a BF8D BFP 8D Ser#: BAAJ 11012XX. It is an 02.
I need to order a new carb. Honda Makes two different carbs for 2002 8HP.
I have looked at the model ID guide on the Honda website and still can not figure it out.
The kicker is manual start (pull the rope), it is connected to the bi motor for steering so this should no affect what carb, and it has forward throttle control for speed. Basically we start it at the back of the boat then everything else si controlled up front. I think this means it is an LRA but not sure. Shaft length does not matter. THe options are: LHSA, LHA, LRA, SA, SHA, SHSA, SRA. LHA, SA and SRA all hav ethe same carb. THe other four also have share the same carb. One is about $120, one asout $145.
Any help is appreciated.
Thanks,
