what motor will work?
niss_det
i have a 76 boat with a merc 302.. the motor is bad i was just wondering if there is a 302 out of a car or truck that would just bolt in and be easier on gas and with more power..
lime4x4
Re: what motor will work?
short answer NO.you probably could use a car/truck engine block but u will have to change the camshaft over to a marine cam and replace all the freeze out plugs with brass core plugs
niss_det
i was just asking if the bolt holes for the mounts and intake/exhaust were the same or not and in what motors
cobia-boat
Yes the bolt holes are the same. The block itself is the exact same, it will need brass freeze plugs.
Gary H NC
The camshaft in an auto motor is much different.It makes the most horsepower at higher rpms as a marine cam creates more power at lower rpms.So the cam will need to be changed.
Ayuh,.....
A Truck motor will give satisfacty service.......Cam,+ All..........
