What navigation lights do I need on my boat.
rbryant1492_mfb
The 1979 chaparell 187xl I just got just has a navigation light on the bow.
And thats it. Do I need to add others lights?
bruceb58
Re: What navigation lights do I need on my boat.
You need a 360 degree white light near the rear of the boat.
BOATS UNDER 12 METERS (39.4')
Powerboats-Separate or combination red and green sidelights, 112.5?, visible 1 n.m., placed above hull at least 1 meter (3.3') below masthead light. Masthead: white, 225?, visible 2 n.m., at least 1 meter above side lights. White stern light, 135?, visible 2 n.m. OR, one all-round (360?) white light (should also have sidelights).
troypolla
He is right a white 360 light near the back. For when anchored.
ECHO 1
360 white ligth stern, the bow light can sometime's be hard to see when aproaching from the rear.
RWilson2526
Actually, the bow light is purposely not visible from the back to let someone know they are approaching a boat from behind.
If you see white only you are approaching from behind
White with red and green you are approaching head on.
White and Red approaching from your right (also meaning he is the stand on vessel and you should yield, kind of like stopping for a "red light")
White and green approaching from your left.
Big Keepers
I'd get a nice perko all around white light for the stern. It needs to be 3' higher than the highest point of your boat. If I'm reading it right, you have an 18' boat? Probably a small cuddy. A 36" all around should be fine.
