I am 4th owner of this boat, all in the family. I didn't pay much.
First owner (my uncle) got rid of the boat because it always ran poorly, and after maintenance, would run great until "we got out of sight of the marina, then would run like crap",
he gave it to my cousin who would be constantly changing plugs,...cousin gave it to his son who never ran it, I bought it cheap. Hull is great, and trailer is awesome... here's my story...
Last season ('10) was my first year with it. Just use it for fishing.
I started by having a mechanic check it out, because it hadn't been run in 4 or 5 seasons. He checked compression, said it was Ok, checked the water pump (OK) said there was oil in the carbs, changed the plugs, put some new gas in it (didn't drain the old gas- internal 30 gallon tank), suggested I run it.
It ran OK most of the year, but not great. It ran. top speed was only 28 MPH, (120HP on a 1200 lb aluminum Crestliner-should go faster, I know), and as
the season ran down, the boat got worse and worse. Probably put 10 hours on it.
In the off season we had the compression checked again-still good- and the carbs cleaned out, new plugs, and the mechanic said he wanted to replace something called "NLA Spark Advancement Link", but was told it's "No Longer Available"...
So he did the best he could with the existing part. He said it should run ok at WOT, might be a bit rough at low RPM, in fact he test drove it and that was exactly as it was.
I got it, it ran great for one day, then crapped out.
Back to the shop, he started from scratch, checked compression again, still good, but now found a bad Power Pack, changed it out, and added a Fuel-Water separator.
Ran great for about 5 trips (maybe 2 hours total) and ran like crap again.
I checked the fuel in the separator, and looked nice. No water or crud at all.
So we disconnected the internal tank and VRO, and premixed 50:1 and used an external tank. We changed out the plugs, which were already fouled after about 3 hours of total running.
It ran great. For about 5 minutes, then choked out, sputtered, and coughed and barely made it back to the dock.
We pulled the plugs, and they were fouled, and wet. Removed the carb cover, and the carbs were oozing milky fuel mixter, as if watered.
So....what next?
thanks,
CapnDan
So....what next?
thanks,
CapnDan
