86 3 cyl 60hp engine Ser#931265
Engine would not start when I bought it. Misfire only. Checked the stator and found it defective. Replaced the stator and at the same time cleaned the carbs. Found the main jet missing in the top carb. Replaced it. Checked and cleaned wiring, trigger, fuel enrichment solenoid. Got it all back together today and tried starting. Backfired once and misfired several times. When I enriched the carbs there was no misfire or backfire,just uninterrrupted cranking. Shut it down and checked the stator and it is ok.
When I replaced the stator the old stator was a CDI with the open coils and the new one was a Sierra was the encapsulated coils, so not sure that the new stator was in the same exact position as the old one. How can I determine the correct position for the stator, I just kinda put it so the wiring worked for hooking up to the switch box (blue and red wires). Is the stator position critical, since its only ignition function is to send an AC charge to the switch box, which is rectified and stored in a capacitor?
I am guessing now, but the flywheel position is critical for the triggers to be in time. Right? I check this by using a dial indicaror in #1 cyl and locating the .464 inch mark? The manual says to move the pointer, but if way off I suspect that I need to move the flywheel. Is this correct? Am I missing something? Thanks JH
