what now????????
dwhyble41
i finally got my 73 johnson 85 hp motor to stay runing after 4 months of trying.took it out the other day for the first time.got on the water putted out at 1/2 throttle.got out away from the docks try to go wot.and the engine just spun like your tranny on a car when it is dieing.the motor is fine at 1/2 throttle but dont try to go any further. what should i do now? :confused: :confused:
BKool68
Re: what now????????
It could be starving for fuel. Try squeezing the primer bulb or pushing the choke in and see if it picks up speed. If so you need to check for restrictions; loose fuel lines, weak fuel pump or dirty carbs. If the motor sat for a long time I would lean towards the carbs.
12Footer
If it's acting like a car slipping on ice, it's the hub in the prop. It has "spun-out", which means the rubber part in the prop has let go of it's bond on the prop shaft hub. Remove the prop, and take it to a prop shop to have a new hub pressed in. About 30bucks or so, and You'll be back in the saddle.
dwhyble41
I had the carbs taken apart and cleaned at the marina just a week ago. I will try the prop idea.<br />Thanks alot for the info. If you can think of anything else, it would be appreciated.
