What oil for 89 johnson gt150 for least smoke
snake91876
What oil would you run in the VRO tank on a 89 johnson gt150 to get the
least amount of smoke while your on the water. Just got this boat motor
had oil in the tank but seems to smoke a fair amount i would like less if possible.
ondarvr
Re: What oil for 89 johnson gt150 for least smoke
Synthetics tend to smoke less, pick one and try it.
kenmyfam
Give it a decarb and then use synthetic 2 stroke oil. TCW-3 rated.
ezeke
For the best results, use a carbon treatment like Carbon Guard or Ring Free in all of your fuel all of the time. If you use BRP XD-50 oil it has the carbon treatment built-in.
You can also use Ring Free or BRP Engine Tuner products for the shock de-carbon treatment.
If you have the Schrader valve on your primer solenoid, the aerosol de-carbon treatment is the preferred method, using an adapter.
http://shop.evinrude.com/dyn_prod.php?p=763644
Also, make sure that the thermostats are functioning properly.
