What oil for lower end?
craigman
Fellas,
1974 merc 85hp. What oil does the lower end take? Is it a special oil?
thanks for any info!
Craig
Alumarine
Re: What oil for lower end?
I believe Mercury Premium or High Performance oil will work well.
craigman
So i take it, it's not regular oil or gear lube then?
treker
The oil that I have from the merc dealer just says Hi Performance Gear Lube they don't tell you the weight (viscosity) on purpose because they sell the oil for 16.00 per quart
craigman
$16 a quart? Yikes!!!!!
treker
That what I said, but I have changed mine twice and still have a couple ounces left
jigmister
so is it safe to use automotive 80w/90 gear oil or is there a marine diffence here beyond inflated cost?
j_martin
Marine gear lubes are designed to keep a fair amount of water in suspension to limit the damage it would do.
I don't think I've paid over 10 bucks for merc high perf gear lube. Whatever it's cost, it's well worth it for the extra protection it gives.
treker
I would also continue to use it, the quart I bought was at a marina at the lake, like gas stations by the exit ramps, I'm sure they get top dollar. Also as I said I have changed twice with a bit left over, so even at the high price it works out to about 6.75 per change, and I know I am using what Merc reccomends
