Re: What Oil Should I Use?
As I run for cover, this is from the current manual:
Crankcase Oil
To help obtain optimum engine performance and to provide maximum protection, we strongly recommend the
use of Quicksilver 4-Cycle 25W-40 Marine Engine Oil. This oil is a special blend of 25-weight and 40-weight oils
for marine engines. If not available, a good grade, straight weight, detergent automotive oil of correct viscosity,
with an API classification of SH,CF/CF-2, may be used.
In those areas where Quicksilver 4-Cycle 25W-40 Marine Engine Oil or a recommended straight weight oil are
not available, a multi-viscosity 20W-40 or, as a second but less preferable choice, 20W-50, with API service
ratings of SH, CF/CF-2 may be used.
IMPORTANT: The use of non-detergent oils, multi-viscosity oils (other than Quicksilver 25W-40 or a
good quality 20W-40 or 20W-50), synthetic oils, low quality oils or oils that contain solid additives are
specifically not recommended.
