The kit I got from Franz looks like this one (it is not the '68 original): http://www.ebay.com/itm/NIB-Force-7...-1-Outboard-/291195117495?hash=item43cc94dfb7
1. Gasket goes between the wear plate and the water pump body (it does not fit well here as it does not seal align near exit port and it would seem to interfere with the impeller - I don't think this is the correct location).
- or -
2. Gasket goes between gearbox housing & wear plate (this is where it fits best - but I don't see the point for sealing this side)
Also additional questions:
- or -
- where should I use the 847 sealant? (I'm thinking metal to metal and metal to gasket joints - gearbox to gasket to wear plate & wear plate to Water Pump housing)
- where should I use Evinrude Gasket Sealing Compound? (I'm thinking water pump bolt threads)
- Is there something (like Aladdin 631 Magic Lube teflon compound) that I should wipe the inside of the pump housing that will soak into the cast metal and make it slick? Even though it is brand new cast metal it just feels dry and not slick.
