what other options do i have for trim pump?
big ken
on my 1977 glastron 165 pre alpha trim/tilt took a crap. it now has motor with metal resevoir and two bolts attaching it to i think the side of gimbal assembly and has two hyd hoses attached to the bottom. can i use an alpha 1 with plastic resivior and mount to deck as long as it has two ports? thanks ken
Re: what other options do i have for trim pump?
Ayuh,.... The short answer is Yes,..... but with Problems...
You'll have to adapt the lines to each other,... They're not the same sizes/ styles of hyd. connections...
I think you'll have to start your swapping from the transom manifold at the bottom of the transom, replacing the Return line to the Pump...
Take out what's there,+ replace with newer, matching the pump...
The Upside might need a fitting change, or possibly Not..... Don't remember...
