What outdrive?
eedwards
I just got a 83 regal princess from a storage auction so i know nothing about the boat.How do it tell what outdrive i have?I know it is Mercuiser ,but is a alpha or bravo?The motor is a 4 cylinder 120.
achris
More fish than mountain goat
Re: What outdrive?
It's either an 'MC-1' or an 'R'... Does it have a flat top or a top with a lifting eye in it?
Flat top -> 'R'
Lifting eye -> MC-1
Chris.......
eedwards
Re: What outdrive?
From the link i was given looks like a Alpha flat top no ribs on the side.
And thanks for the link.
achris
Re: What outdrive?
That's called an 'R' drive. R for 'Redesigned'...
Chris.......
eedwards
Re: What outdrive?
Chris.......
Ok well i confused now because in the link the r drives show a loop on top and ribs on the side.
achris
Re: What outdrive?
I suspect the link is to a non-Merc source... This is a page from the Merc service technician's handbook....
1983 was the introduction of the 'R'.....
I looked at the link... They are SOOO wrong it's not funny. They is no such drive as a 'pre-Alpha' (I wish people would STOP using that term, it's very confusing) and the 'MR' and 'Alpha one' are different... It's very minor, but they are different... Have a look in the ADULTS ONLY thread and download the history and ID of Mercruiser drives...
attachment.php
Re: What outdrive?
Ayuh,... I believe you have either the MR, or the Alpha 1...
Not that it really matters til your buying Internal parts for 'em...
Drive for Drive,... They All interchange with each other, Up to the Gen.IIs, which don't interchange with Anything but itself...
eedwards
Re: What outdrive?
Ok Don yours shows I-R for a 1983 120.So i would be ok with alpha parts?I need all new bellows and like to go get them today.I also need i new line for the lift and i should be good to go.
Don S
Re: What outdrive?
You need to go by the serial number of the drive, not the year of your boat. It's not unheard of for an 83 boat to have an 82 engine package in it. Boat years start on calander years, engines don't.
eedwards
Re: What outdrive?
6273691 are the only numbers i see on the outdrive they are on the port side there is also a big B stamped close by the numbers.
eedwards
Re: What outdrive?
So the transom seal kit should say it fits a R
