Slicktified
- Joined
- Jul 5, 2010
- 9
I own a 75 Slickcraft ss-194 with a 188hp Mercruiser 888, 17 feet, v-hull, guessing weight around 2900 pounds. The prop is beat-up and I'd like to get a new one. Also according to the tach I'm turning 5300 rpm WOT and 43 MPH on the speedo (no gps yet). The service manual states max rpm at wot should be 3800-4200 rpm, so I'm WAY over that.
Looking for a prop for general cruising, pulling tubes, skiers, wakeboards & etc. Kind of leaning towards a 4-blade prop for the smoothness(what I've read) Any suggestions on Dia and pitch?
Anyway the only markings on the prop that I see are a set of numbers on the hub between each blade. The diameter with a tape measure looks to be 14", 3-blade. Can anyone ID this prop? I photo-chopped the 3-sets of numbers into 1 pic.
Thanks in advance.
Thanks in advance.
