nitrosteve
- Joined
- Jul 19, 2009
- 154
1. 1998 180 Monterey
2. 18ft,7ft 9 beam, dry weight 2100lbs
2a.190hp
3. 3 people, 20 gallons
4. Mainly cruising at 30 mph or faster.
5. I wouldnt consider it a deep-v but I don't know the dead rise
6. 1987 3.0 140hp Mercruiser I/O wrong year I know but it fit.....
7. 140hp Alpha one gen 2 2.0 ratio
8. 4400-4800
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. ?
11. no
12. 13.75 x 19 Aluminum not sure the maker
13. 4950 rpm 42.1 mph GPS 3 people 10 gallons
14. Sea Level
15. Motor is in perfect working order.
16. Prop has been on boat for 6 months
17.would like higher cruising speed at less rpm. I would also like to lower the wot rpms into the correct range. It has very little damage mostly cosmetic.
18. See 17
19. Hmmm not sure I will get a chance to do this. I can tell you 30 mph with 3 in the boat 10 gallons of fuel is about 3700-3800 rpm. 35 is right at 4200rpm.
On a side note I have a 14x17 vengence SS prop that seems to take alot more positive trim and raise the bow. My current prop planes out well but you cannot trim it up near as much without it washing out. Not sure why this is. Thanks for your help..
__________________
2a.190hp
8. 4400-4800
10. ?
11. no
14. Sea Level
18. See 17
__________________
