What Prop Do I Use?
Keefbikes
I Just bought a 89 115hp Mariner 25inch. I am putting it on my 89 19ft Cuddy Bayliner. I live in Utah so my elevation to each lake can change drasticly. What prop size and pitch is going to be the best for my boat? I fish alot but also do some water sports. I would rather be concervative and put less strain on the engine to make it last longer than get a faster speed. Can any one help? Also what is the best way to drain my fuel tank on the boat?
Silvertip
Re: What Prop Do I Use?
To drain the fuel tank, disconnect the fuel line at the engine and siphon it out. Just curious, isn't a 25-inch shaft a little long for that boat? Prop is a wild guess -- probably a 21 pitch. Someone with that setup will probably be along with a more accurate response.
JB
Moving this to the Prop forum.
Keefbikes
Im not sure if that is to big for my boat, I believe my last Force was a 25". How do I measure the shaft Length? How do I siphon it with the snap on attachment on?
