farginicehole
- Joined
- Apr 15, 2003
- 482
I have a 1991 Alumacraft 185 CS Competitor with a 1989 Evinrude 150 XP. I bought the boat used a few years ago, and it has the stock(?) 15" x 17 pitch aluminum prop. At full throttle I get around 5000 rpm, at least according to my tach. The boat only tops out at around 40 mph (my GPS agrees pretty closely with the speedometer). I don't need to set any water speed records, but it seems like I should be able to get a lot more out of this rig. Compression checked out around 95-105 for all cylinders back when I bought it. Seemed kind of low, but I'm told that these particular OMC motors had lower compression. Assuming all is well with my motor (and I do plan to decarbonize it and replace plugs as well), does anyone think I should spend the money and try a stainless prop? I'm hoping someone out there has a similar setup and can give me some idea of what size/pitch prop to try. I'd hate to spend $300-400 and find out I was way off. I've been apprehensive about going with any more pitch, as I figured my rpm might drop even lower. Someone told me that a stainless would help get more of the bow out of the water though (by being able to trim the motor up even further) and that my rpm and top speed would actually increase substantially. Any thoughts? Thanks much!!!
