What Prop should I use??
I have a '87 Bayliner,2550 with a 9'beam,5.7 Merc.outdrive.I want to improve performance and would like to install a SS prop.What pitch (SIZE) would be recommended?? WOT only gets me 25mph! Any Info would be appreciated.
chuckz
Re: What Prop should I use??
In order to answer your question, you need to post the size of the prop on the boat now and WOT RPM.
walleyehed
You're about 1000RPM shy of where it should be...maybe even 1500. we turn our 5.7 5500RPM all day long and have since about 1990.<br />Has it always been this way????
LubeDude
Are you sure your tach is accurate? :eek: <br /><br />Thats a small Pitch prop, I think something is amiss. :confused:
walleyehed
I think the readings are correct, LD...the speedo may be off by 1, maybe 2MPH, but 3600 with a 15 on that unit comes close to 23-24MPH.<br />That's figuring a very low slip ratio, so I think the tach is good.<br />I DO think something else is troubling us here though...our 22 wellcraft cuddy with a 5.7 will spin a 19 6k...we run a 21 to keep it managable.
LubeDude
Originally posted by walleyehed:<br /> I DO think something else is troubling us here though...our 22 wellcraft cuddy with a 5.7 will spin a 19 6k...we run a 21 to keep it managable.
This is what is troubling me here, it seems that the 15P should be spinning a higher RPM.
walleyehed
Exactly.....we may have engine issues, possible marine growth, bad trim cylinders not going all the way down, hull full of water, etc..<br />My question to him is "Has it always been this way?", and do we know for sure it's a 15 pitch?
Thanks All: I ran the boat 1st time last summer,just purchased.Trim tabs seem to go all the way down,I am 99% that prop is stated size(its in storage)Bottom is painted,no growth.Engine seemed to start/run fine.Any ideas on where to start looking/fixing????
Originally posted by walleyehed:<br /> You're about 1000RPM shy of where it should be...maybe even 1500. we turn our 5.7 5500RPM all day long and have since about 1990.<br />Has it always been this way????
walleyehed
May need to have a tech do a tune-up, webegone...<br />Your RPM seems to be correct in regards to speed with a 15" pitch.<br />Tabs are down you say, but is the drive going clear down???<br />When on plane, can you raise the tabs without problems??? Does the bow stay down??<br />If tabs are up, what happens if you start to trim up?? RPM go up?? any advance in speed at that point??<br />I know, too many questions, but lets make sure we're not fighting the trim systems (tabs and trim).
