Re: What prop to go?
Good answer from Link. The most important thing is to use a prop that lets your motor operate in the upper quarter of the manufacturer's maximum RPM range. If this isn't giving you the hole shot you need, you need another, lower in pitch, to use for skiing, tubing, whatever. Venting the prop is another possibility to improve hole shot. Do a search on "Venting" and you'll find a wealth of information. I use a 17" and a 19" pitch prop for about the same circumstances and have one as a spare when using the other. Venting helped my 19" hole shot, but not nearly as much as changing to the 17"
