what prop
craig stevens
i have a 76 fiberform 24' cuddy twin 165 mercs and legs. weight appr. 4200 lbs. what prop would be best for overall use
steelespike
Re: what prop
Instead of having to go through a whole Q&A session.It would be better if you tell us your present prop size,gps speed and rpm.And your typical boat activities and load. Selecting a prop is like trying to select the best overall single gear to use on a car.If running on the flat no load high will work add load and hills will change that and so on.Want great hole shot another change.A prop is a comprimise based on the required performance.
craig stevens
Re: what prop
my prop size is 19 p. rpm on starboard is 5000 port is 4200 at 39 mph. im thinking my props ar diff. they both say 19 p but on has many additional numbers and the rpm difference. i nailed a log today and bent one so nows the time to match them. any help would be appreciated
Re: what prop
Ayuh,.........
Get 2 new Props that match the 1 on the Port drive...........
Your starboard RPMs are Too High for that motor.........
craig stevens
Re: what prop
what should my rpm be and what prop. i use the boat for fishing and some areas i fish are 20 miles away so i would like to get there quickly but don't want to hurt the engines
