What prop
Slow Ride
Re: What prop
Many factors to consider! Weigh and design of boat will play a major role as well as what you do with the boat. Contact your local Mercury dealer. I'm almost positive Force was a Merc product. Anyway, they will be able to help you select the right prop diameter and pitch for your application. A good dealer might even give you several props to try or even acompany you to the water to help if your buying new and not used!
steelespike
Re: What prop
Yes; it uses Merc props if its a 4 1/4" gear case through hub exhaust.
Your prop will very likely have a prop with a Merc number beginning with 48 under the prop nut.
