What really is the WOT on a 7.4L - no really
Elk Chaser
The Seloc manual says that the WOT is 4200 to 4600 on a 7.4L Bravo.<br /><br />However this spec.........<br /> http://www.marinemechanic.com/specs/mc-454SC.htm <br />says it is 4800 to 5200<br /><br />Holy bat dung Bat Man that is a huge difference in WOT. :confused: <br /><br />I was running on the assumption that I should be at the 4200 to 4600 range (based upon my manual) <br />and now I'm not so sure about that. <br /><br />Anybody know the answer for sure?
f_inscreenname
Re: What really is the WOT on a 7.4L - no really
I always thought with a middle of the road prop it would be 4600rpm’s.
Airpacker
The 7.4 with cast crank and pistons was rated at 4600 maximun rpm. I can tell you that you can spin it at 5000 but I would not run it over that. 4800 to 5200rpm is for a 454 mag with a steel crank and forged pistons.
WSUDERMAN
Don't forget the valve train. @ 5200 + with stock springs you might start to see some float....
kcole683
Doesn't Mercruiser put a plate on the engine with this info anymore?<br /><br />My old 1985 merc. has a plate with tune up specs and WOT info etc.
It's Also a Very Long, Expensive ways from 330hp, to 425hp, or 525hp.................... :D <br /><br />Stick to Your Manual........
Elk Chaser
OK, but I am due for a new manual, the Seloc is gettimg very worn out (had it through three boats now) and it is not specific to the 7.4L. <br /><br />So when I buy a new one I can base my assumptions on the WOT listed in that one............ :confused: <br /><br />Engine was rebuilt and I was told it's built stock mercruiser, however it has raised pistons and aluminum roller rockers, performer intake, holley carb, thunderbolt ignition, rv/truck cam and I'm not real sure what else unless I tear it down. No plate telling me anything anywhere on the engine and even if it had one I could not really rely upon it.<br /><br />I'll stick to the 4600 max and go from there.
Yes,<br />IF you buy 1 for the 330hp, Standard Merc. 7.4l..... <br />IF your motor Is/Was a Standard Merc. 330hp,<br />You have a Standard Duty, Cast Crank, 2bolt Mains...........<br />Then You'll Still have to stick to the 4600rpms........<br />It Appears that your overhaul Might have upped your hp a Little,<br />But, Your Still running a Basically Stock motor......<br />Changing Manuals will Not give you the Heavier Hardware Needed for the High Output 425hp, or the 525hp motors, which run at Higher RPMs.......<br />Your motor,+ the 2 listed on the page you show with Higher WOTs, Share the Same Displacement .......<br />But, Little Else............... ;)
LubeDude
Most have bult in rev limiters, not sure about your vintage though, 4,600 is good though, your cam isnt going to produce any more HP past that anyway.
Elk Chaser
Thanks guys, I appreciate your help.<br /><br />I completely understand the horse power differences I guess I did not relate the top numbers in the chart (link above) to be HP. My dumb mistake.<br /><br />Nope, no built in rev limiter that I know of, (thunderbolt ignition have one?) matter of fact I installed a motor protector but it is set up at about 4600 to 4800 or so.
GL2238
I have 7.4MPI 2001 with B3. Motor only turns max at 4100 fully trimmed (26" SeaRay Sundancer). All diagnostics check A-OK. Another SeaRay and two Wellcraft with same I/O and block run 4300-4600. Props are the same on all four boats.<br /><br />Could rev limiter be at fault?<br /><br />Gerald
