What rpm is good idling ?
johnson426
hey guys I have a 1986 90hp johnson outboard and I was wondering what rpm is good for idiling ? currently its idiling around 1000 rpm
mamm7215
Re: What rpm is good idling ?
1000 rpm out of water on muffs is correct, boat in water should be about 600 rpm
johnson426
As of right now my boat idles at 1100 in water, should I adjust to 600 ? will it be too low ?
5150abf
Get it as low as you can and not have it stall, the slower it is going when you shift the easier it is on your lower unit, banging into gear puts a really bad shock load on the clutch dog and gears, they will last alot longer if you lower the idle speed.
Dhadley
If the motor is running properly and is basically healthy it should idle at 650 rpm in forward in the water.
