what RPM'S is the limit on the ignition of a 1995 60hp 3 cyl Rude
phillnjack2
Ensign
The engine is
1995 Evinrude 3 Cylinder 60hp.(54ci)
Model no BE60TLEOC
Serial no G 03751787
Made in USA
I need to know at what revs the limiter on the ignition comes in at ?
ive been told by someone at brp its 7,000 rpm's is this correct ?
or is it 6500rpms like someone else has told me ?
ive had a fair bit of dodgy/bad info from BRP about these engines in the past so thought i would ask on here.
phill...:)
WernerF
Re: what RPM'S is the limit on the ignition of a 1995 60hp 3 cyl Rude
Your engine has a CD3AL67 power pack => nominal limit at 6,700 rpms. You can expect +/-300 rpms tolerance.
phillnjack2
Ensign
cheers for the info
so anywhere between 6400 and 7000 it will kick in.
thats good to know, it means a certain prop i have is doing what i expected it does and makes the slip on the prop about right too.
i will be using a rev counter from now onwards ,but wanted to verify what the rev counter will show if take it to the limit (i hope not).
thanks again for the info.
phill....
