Here?s the short of the long with the engine. It?s a marine remanufactured block with low hours and ran according to the PO. It sat unused for over a year and the PO thinks rain water got into the air intake causing it to seize. I latter found water in the oil is why I assume the block is cracked. That could be my fault though. Water could've got into the engine when I had the heads off. The tarp blew off. Funny thing is when I removed the heads it now turns over freely for some reason. No signs of water in the cylinders. I got new head gaskets and torqued the heads down. Compression readings going off memory was 163 psi +/- 5 in all cylinders. At this point, I'm concerned there could be a crack in the water jackets. I don?t want to put any money into it even though it may be fine. I need an OB.
What?s it worth in parts?
Thanks in advance, Don.
