Re: what,s the standard prop. 1994 120 hp force by merc.
These props should be listed right here at iboats store. They may also have a prop calculator for pitch.
Diameter is 13 inch I believe it is still a small hub --4 inch-- prop. Pitch--you are asking how high is high and how hot is hot.
However, with an 18 foot boat I would start with no higher than 17 pitch. This is where you really need to calculate because it will depend upon the weight of your boat too. However, maybe someone with an 18 foot Maxum will jump in and tell you what size they are using.
Anyway, you want to prop the engine so that it runs at about 5000-5200 RPM or maximum RPM range at wide open throttle.
