what saftey stuff is needed for a 21 footer
gomer68
Hey,all new guy here:D Anyways i working on a 21ft boat for the bay for this summer. Can someone tell me where i can find a list of stuff i need like, life jackets,flairs ect.. thanks.
southkogs
Re: what saftey stuff is needed for a 21 footer
Yes. Check your local boater safety regulations. That will give you the minimums your state requires. From there take a safety course which will help you figure out some added items that experienced dudes(ettes) in your area suggest.
Welcome aboard gomer.
Home Cookin'
FIRST take the safety course-- a live one at that, where you can ask questions, not on line.
Then you'll have your list.
and they may not mention it, or at least not emphasize it, but a properly rigged anchor is your most important safety equipment for coastal boating.
Always have something you can bail with. And a hand pump. And a paddle.
Always have a light even if you never go out at night. SAR can see a minimag from miles away. I know one case where two people on a small sailboat died the bay when if all they had was a light they probably would have been fine.
Read the thread about "cheap life vests"
never, ever, consider your cell phone to be a safety device. They are way too fragile to even think they can save you. Plan as if they don't exist.
A CD is a good cheap signal device in the daytime.
UncleWillie
Welcome Aboard! :welcome:
All good advice so far.
You are thinking safety before you even got close to the water! Good!
With your first question we could give you a better answer if we knew where you were located.
The Boating Course is required by Law in some states.
Someone here may even be a neighbor. See the instructions Below.
VVV
spdracr39
boating course !!!!!!
oldjeep
Your state boating manual will tell you everything you need to know.
