What should compression be 1989 Yamaha 200 hp??
bowhuntrrl
I'm looking at a 1989 200 hp yamaha outboard. The compression is fairly even 110-120 on all cylinders. That seems a bit low to me. Does anyone know the spec for what it should be ??? TIA.<br /><br />bowhuntr
JB
Re: What should compression be 1989 Yamaha 200 hp??
Howdy, Bowhuntr.<br /><br />That is fine compression. <br /><br />Anything over 100 psi is okay, but the important number is the difference between high and low cylinder, should not be over 10%.<br /><br />Good luck. :)
Capt Ken
Sounds good to me also. Remember that cranking speed is in direct relation to compression. If the battery was not real hot, it can result in a lower compression reading. Once had an engine that the first cylinder checked fine and the cylinders got lower as I went. Battery was getting weaker and affecting the cranking speed.
